Hi, I am passing the cell values for a specific row in a table panel in the link url by using __cell_n. Is there a way to also get the column name for a specific cell (e.g. __cell_1) so that I can pass that in the url as well?
No, that’s nor supported.
I’d like this. I’ve got repeated table panels and I want to link out to a dashboard from each panel to a chart with the specific metric name for that panel but the metric variable from the template contains a comma separated list of all the values selected, not the specific one for that instance of the panel, yet it appears in the table column header.
I suggest you open a feature request for it at Grafana’s github repository.
Is that under ‘issues’?
Sorry, yes here’s the link https://github.com/grafana/grafana/issues/new
