Grafana v8.3.4 (a551d74b11)
- What are you trying to achieve?
I want to view the tooltip for a section of the bar chart
- How are you trying to achieve it?
Hovering over the bar chart
- What happened?
I am viewing a tool tip for another point at the same height (presumably this has a value of 0 so is occupying the same part of the bar chart).
As you can see in this screenshot, I want to see the tooltip/label for the yellow section of the bar chat. However, when I hover over, it shows me the tooltip for the blue label, which presumably is zero so appears at the same position.
How can I show the label of the part of the graph under the mouse, not a nearby point?
I would see the tool tip for the relevant section
- Can you copy/paste the configuration(s) that you are having problems with?
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisLabel": "",
"axisPlacement": "auto",
"barAlignment": 0,
"drawStyle": "bars",
"fillOpacity": 100,
"gradientMode": "none",
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"lineInterpolation": "linear",
"lineWidth": 1,
"pointSize": 5,
"scaleDistribution": {
"type": "linear"
"showPoints": "auto",
"spanNulls": false,
"stacking": {
"group": "A",
"mode": "normal"
"thresholdsStyle": {
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 12,
"w": 8,
"x": 8,
"y": 0
"id": 4,
"interval": "1d",
"options": {
"legend": {
"calcs": [],
"displayMode": "list",
"placement": "bottom"
"tooltip": {
"mode": "single"
"targets": [
"datasource": {
"type": "prometheus",
"uid": "000000001"
"exemplar": true,
"expr": "sum(increase(failed_mpoint_counter_total [1d])) by (id)",
"interval": "1d",
"legendFormat": "{{id}}",
"refId": "A"
"title": "Failed MPoint Counter",
"type": "timeseries"
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
N/A
- Did you follow any online instructions? If so, what is the URL?
N/A
