How to get instant value inside query which contain not instant value
Hi, i’m new to Grafana and prometheus. I’m trying to achieve query like (instant value * non instant value). I tried to use @ end() but got an error
"2:25: parse error: unexpected character: '@'"
Also i tried to separate queries and enable “instant” checkbox, but i’m not able to use query result in my expression. So, is there any another ways to achieve my goal?
Please can you give us a little more information to help us understand your
situation?
For example:
  • What happened?
  • Did you receive any errors in the Grafana UI or in related logs? If so,
    please tell us exactly what they were.
Thanks,
Antony.
