How to fix Bar chart based on SQL
Problem statement :
My bar chart is based on Postgres SQL:
select the_date, name, max(value) as max_value
from T
where the_date >= DATE(‘2023-08-01T07:00:00Z’) and the_date <= DATE(‘2023-09-01T06:59:59Z’)
group by the_date, name
order by the_date, name
In Bar chart properties I specified X Axis as “the_date”
In Postgres table the “the_date” column has type “DATE”.
Problem #1: currently the bar chart shows the x-axis labels as several identical values
17:00:00.000 17:00:00.000 17:00:00.000 17:00:00.000 17:00:00.000
But I want to show on X-axis the dates in format MM-DD, for example
08-01 08-02 08-03
Problem #2:
All bars for the same date should be under the single X-axis label.
But currently every bar has his own X-axis label.
Suggestion: You can use business charts
Step 1: Create table and insert data in it.
Step 2: Select business charts visualizations to display data on panel.
Step 3 : Use this query to fetch the data
Step 4 : Write function code mention below
return {
dataset: {
source: [
[‘Date’, ‘A’, ‘B’],
[‘08-01’, 10, 15],
[‘08-02’, 20, 25],
[‘08-03’, 30, 35],
[‘08-04’, 40, 45]
series: [
type: ‘bar’,
data: [10, 20, 30, 40],
type: ‘bar’,
data: [15, 25, 35, 45],
xAxis: {
type: ‘category’,
data: [‘08-01’, ‘08-02’, ‘08-03’, ‘08-04’],
yAxis: {
type: ‘value’,
Final output:
cool stuff but the chart is using static data, not the data coming from the database.
Thank you for pointing that out! We’re glad you found it cool. We’ll definitely work on integrating dynamic data from the database for a more robust and real-time experience. Stay tuned for updates, and feel free to share any other suggestions.
Fixing a bar chart based on SQL can be tricky, but once you get the right query, it is super rewarding. Happy to see more people tackling this challenge!
