Bar char based on SQL with 2 items in GROUP BY
My bar chart is based on Postgres SQL:
select the_date, name, max(value) as max_value
from T
where the_date >= DATE(‘2023-08-01T07:00:00Z’) and the_date <= DATE(‘2023-09-01T06:59:59Z’)
group by the_date, name
order by the_date, name
In Bar chart properties I specified X Axis as “the_date”
In Postgres table the “the_date” column has type “DATE”.
Problem #1: currently the bar chart shows the x-axis labels as several identical values
17:00:00.000 17:00:00.000 17:00:00.000 17:00:00.000 17:00:00.000
But I want to show on X-axis the dates in format MM-DD, for example
08-01 08-02 08-03
Problem #2:
All bars for the same date should be under the single X-axis label.
But currently every bar has his own X-axis label.
Welcome @mlubinsky
What data do you see when running the same query in pgadmin?
select the_date,
   name,
from T
where the_date >= DATE('2023-08-01T07:00:00Z')
and the_date <= DATE('2023-09-01T06:59:59Z')
For SQL above I see records like this in PG Admin
2023-08-02 name_1 20.0
2023-08-02 name_2 25.0
2023-08-02 name_3 14.0
2023-08-04 name_1 18.0
2023-08-04 name_2 12.0
2023-08-04 name_3 15.0
Exactly the same records I see in Grafana Table, it means Grafana got the right dataset. :slight_smile:
So it results in this, so grafana is doing it correctly?
The X-axis labels on image in post above is different from mine.
I got labels like this instead of YYYY-MM-DD:
( this is problem #1 in my original post).
The problem #2 in my original post is present on image in post above:
every data point has individual X-label date even it belong to the same date.
I need to show values for the same date under the single X-axis date label (using different colors for different names).
I need something like left bar chart here:
I know how to assign the individual colors to names, but I do not know how combine them under the single common date.
Or stacked
This is almost what I want,
But there is one problem:
On screenshot above I see the legend like this:
value name_1
value name_2
value name_3
Question: how to remove the prefix “value” to show only
name_1
name_2
name_3
Thank you a lot!
I am having a problem in understanding the screenshot above.
I understand only that the 2nd transformation is applied:
“Grouping to matrix”.
On screenshot above I see under “Grouping to matrix”:
Column: metric
In my case I have the drop down list
value name_1
value name_2
value name_3
But it is not clear for me to how to remove the prefix “value”.
I want to clarify that the names list and the number of items in the names list is not fixed:
name_1
name_2
name_3
name_N
Hence the solution for removing prefix should not
ask user to
apply transformation for every individual name_N by clicking on every individual name
Do you have a better solution?
I found this workaround: assign the empty alias column name in SQL:
select the_date,
name,
max(value) as " "
from T
You can follow our detailed document.
