Centos 7 -
How to see data from OP5, installed Nagflux etc.
followed below link and setup everything
[OP5 Monitor - How to send metrics to Grafana –
OP5 Monitor - How to send metrics to Grafana – Support - ITRS Group -
Wants to add ITRS OP5 monitoring tool in Grafana - What happened?
I have successfully added data source (InfluxDB) - What did you expect to happen?
I wanted to see data whatever available in OP5 - Can you copy/paste the configuration(s) that you are having problems with?
unable to see any Grafana plugin for ITRS OP5 - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
there is no error however not sure how to see OP5 data - Did you follow any online instructions? If so, what is the URL?
followed below URL however not able to fetch OP5 monitoring data
Please Help me to fetch data from OP5
Welcome
Maybe use the api?
https://docs.itrsgroup.com/docs/op5-monitor/7.5.0/topics/api/monitor-api.html#Example_response
Then use plugin such as infinity or apache echart to visualize what you need
Hi there,
not sure how to add that, any reference or any steps which can help me ?
Hi there,
nope i have not worked on OP5 API.
i followed below link and installed
OP5 monitor ,
Influxdb,
Grafana,
Nagflux
(OP5 Monitor - How to send metrics to Grafana – Support - ITRS Group)
however unable to link or fetch or connect things from OP5 data to grafana , please suggest
