I want to extract the results only for the steady state duration.
For example: I am gonna run a test with below settings.
- Ramp up - 10minutes
- Test Duration - 1 hour
- Ramp down - 10 minutes
Total duration will be - 1 hour and 20 minutes
I see, k6 provides an external outputs command to export the raw data into a CSV file using ‘k6 run --out csv’, how do I get only steady state duration without rampup and rampdown period?
Thanks in advance.
Hello @jabastin.patturaja,
unfortunately, k6 doesn’t support natively this use case yet. We have an open issue tracking it: Tag metrics from different stages · Issue #796 · grafana/k6 · GitHub.
In the meanwhile, you could use some workarounds:
- Filtering the text output by timestamp: you could filtering textual outputs by timestamp excluding the ramp-up and ramp-down stages using a stream editor tool (e.g. grep, sed or jq for json).
- Query from a data visualization tool: you could use Grafana to query a datasource where you exported your metrics.
- Script using different scenarios: coding a script using different scenarios for your different stages. You can have 3 scenarios with a stage each, via the
startTime scenario option (e.g. set gracefulStop to 0 for all scenarios and the startTime of the second scenario to 10m then the third to 1h10m) - then metrics from the different scenarios will be tagged appropriately.
