So at present I have json data as displayed below
“inv”: 10,
“geo”: [{“key”: “usa”, “value”: 10}, {“key”: “canada”, “value”: 0}],
“inv”: 3,
“geo”: [{“key”: “usa”, “value”: 3}, {“key”: “canada”, “value”: 0}],
Now I want to show values in table with columns as “inv”, “usa”, “canada”
How can I achieve this?
Hi, I guess you’re using Infinity Plugin for that?
Unfortunately, I’m not sure how to do it in plain UQL.
You could use UQL parser with jsonata query like this:
parse-json
| jsonata "$map($,function($v) {{'inv': $v.inv,'usa': $v.geo[key = 'usa'].value,'canada': $v.geo[key = 'canada'].value }})"
Or you could choose to use Backend parser, you could use jsonata code out of the box:
$map(
function($v) {
"inv": $v.inv,
"usa": $v.geo[key = "usa"].value,
"canada": $v.geo[key = "canada"].value
(I find jsonata easier and ChatGPT can do jsonata
Here’s a screen with jsonata configuration
Hope that helps anyway!
yosiasz
3
how does this look?
$.geo.{
'inv': %.inv,
key : value
https://try.jsonata.org/oFbxrqMOk
You can also use the following UQL
parse-json
| mv-expand "geo_item"="geo"
| project "inv", "key"="geo_item.key", "value"="geo_item.value"
Learn more about this UQL commands at UQL Parser | Grafana Plugins documentation
This one won’t work as inv, canada, usa belongs to only one item property.
“inv”:10,
“canada”:0,
“usa”: 10,
“inv”:10,
“canada”:0,
“usa”: 3,
is what I am looking for
But this will create two records with same inv and each having different country
“inv”:10,
“canada”:0,
“usa”: 10,
“inv”:10,
“canada”:0,
“usa”: 3,
I need a structure like this
I am getting this error while trying to replicate your solution. Any help?
Okay you had an syntax error, the end braces should be ‘)’ not ‘}’. Then it works
