Hi everyone,
I have the following JSON data:
I’d like to format this data into a table, where each “metric” (p50, p90, p99) appears as a row, and the other details (timestamp, attributes like git_repo, branch, git_commit) are columns. Here’s an example of how I imagine the table:
I have tried using UQL like, to just extract some data:
parse-json | jsonata "metrics.{ 'time': $$.timestamp * 1000, 'Metric Name': name, 'Metric Value': value }"
But I still have this in Grafana:
How can I structure this in code? Any advice or examples would be greatly appreciated!
Thanks in advance!
can you post the actual json, instead of a snip please?
Hi, not a UQL fan, but if you’re using infinity plugin (probably you do) and switch to a backend parser, you can use following jsonata code:
$map(metrics, function($v, $i) {
$merge([{
"timestamp": timestamp,
"metric": $v.name,
"unit": $v.unit,
"Value": $v.value
}, attributes])
might need to organize fields though
Sample:
"timestamp": 1706220908,
"metrics": [
"name": "p50",
"unit": "us",
"value": 56
"name": "p90",
"unit": "us",
"value": 125
"name": "p99",
"unit": "us",
"value": 280
"attributes": {
"git_repo": "https://github.com/mytest/test",
"branch": "main",
"git_commit": "6995e2de6891c724bfeb2db33d7b87775f913ad1"
"timestamp": 1706221200,
"metrics": [
"name": "p50",
"unit": "us",
"value": 60
"name": "p90",
"unit": "us",
"value": 130
"name": "p99",
"unit": "us",
"value": 300
"attributes": {
"branch": "main",
"git_commit": "7a9f8c1b2dcf134defabcfe329cf5f9a58c8d9d6"
Update after data sample:
$reduce($map($, function($item) {
$merge([{
"timestamp": $item.timestamp,
"metric": $v.name,
"unit": $v.unit,
"Value": $v.value
}, $item.attributes])
}), $append)
something like this should work
Thanks for the suggestions, but nothing seems to show (No data) after adding it.
Before:
After:
try changing the parser to backend…
You could use jsonnata in uql, but it’s less readable, so I’d suggest changing the parser to backend instead of UQL
That’s it. Thank you very much @dawiddebowski and @dawiddebowski !
Just one question, when I added a second timestamp with similar data, the table seems to show results duplicated.
Removing the function:
when I did the jsonata code I created a loop for every item in the root list (the first map) and then inside I made a loop over all metrics (from all of the objects), so right now you got duplicated data and if you had three jsons, you’d get tripled
sorry bout that.
Fixed code:
$reduce(
$map($item.metrics, function($v, $i) {
$merge([{
"metric": $v.name,
"unit": $v.unit,
"Value": $v.value
, $append)
notice $item.metrics in the second map
crawling up the ladder to the parent using %
$.metrics.{
'name': name,
'unit': unit,
'value': value,
'timestamp': %.timestamp,
'git_repo': %.attributes.git_repo,
'branch': %.attributes.branch,
'git_commit': %.attributes.git_commit
https://try.jsonata.org/XrbztwdP9
I have tried also this inline approach, but I don’t know what I’m missing in the UQL
parse-json
jsonata "$.metrics.{
'name': name,
'unit': unit,
'value': value,
pay close attention to the uql I posted and also checkout the uql doc for jsonata
https://grafana.github.io/grafana-infinity-datasource/docs/uql
parse-json
jsonata "$.metrics.{'name': name,'unit': unit,'value': value,'timestamp': %.timestamp,'git_repo': %.attributes.git_repo,'branch': %.attributes.branch,'git_commit': %.attributes.git_commit}"
This works, thanks!
