Grafana v11.1.4 on ubuntu-20.04 -
Want to execute a query when a specific Variable value is selected in the dashboard -
Created a custom variable called “Value”. Created two queries A and B. Trying to Execute query A when “Value” is selected as 10. and execute query B when “Value” is selected as 20. -
What happened?
Not able to perform the query depending on the selected value from variable. -
Did not get any error -
Hello [dharapushpendu],
We are working on a Grafana dashboard where the requirement is to execute different queries based on the value of a custom variable. For example:
- If the variable
Valueis set to10, we want Query A to execute. - If the variable
Valueis set to20, we want Query B to execute.
Currently, we are facing an issue where the queries are not dynamically executing based on the selected variable value. Even though we have defined a custom variable (Value) in Grafana, we are not able to link it effectively with the queries.
Could you help us verify if there is a specific method or setting required to conditionally execute queries based on variable values in Grafana?
Thank you!"
You can follow this detailed document on how to to execute different query with custom variable value
