Grafana v10.3.1 (00a22ff8b2) -
By query, I’m trying to filter values from a variable based on a constant variable defined. -
SHOW TAG VALUES
FROM <measurement>
WITH KEY = "animal"
WHERE
("animal" =~ /"catXX.*/ AND /^$mamiffer$/ = "cat")
OR
("animal" =~ /"dogXX.*/ AND /^$mamiffer$/ = "dog")
What happened?
Empty output. -
I’m expecting that in the animal dropdown menu only certain animals are shown based on the value selected from the mamiffer dropdown menu (which is a custom variable with manually defined values), with a specific regex string.
The logic could be summarized as: select animal values from the database:
- if the “animal” starts with “dogXX” and the value of “mamiffer” is exactly “dog”.
- else if the “animal” starts with “catXX” and the value of “mamiffer” is exactly “cat”.
Thank you in advance for the help.
