How to display mysql select data as time serial graph
I would like to save Linux’s iftop command in DB and display it as a time series dashboard through sql query.
The query is:
SELECT
  UNIX_TIMESTAMP(timestamp) AS time_sec,
  bytes AS value,
  CONCAT(src_ip, ":", src_port, " -> ", dst_ip, ":", dst_port) AS
FROM
  network_traffic.traffic_log
WHERE
  $__timeFilter(timestamp)
ORDER BY
  timestamp
I want the y-axis to display bytes, the x-axis to display time, and metric data to be displayed when the mouse is hovered over.
The concat should be aliased as metric
Also the query result type should be set to time series and not table
Time Series Graph from MySQL Data
