Hi, I have two variables configured
A: label_values(host{environment="$env"},instance)
B: label_values(host{instance=~"$A"},host)
Both A and B are configured as Multi-value and A is used to query metrics and create repeated panels. Variable A can also be displayed in repeated graph title correctly but B can only be displayed as first value in graph title.
I cannot use B directly in the graph metrics query because only instance (IP address in my case) is available in the datasource.
So I’m wondering if there is a way to make B also being displayed correctly? Thanks!
