Hello Everybody,
I have a very basic question. I am developing a grafana plugin that should make some http request to display an image.
However, is it possible to make the http request in the panel plugin? Or should I create a data source plugin for that?
To make the http request is there any grafana http library? Or should I use an alternative library as axios?
Thank you very much for your help!
Cheers,
Turtles
Hello.
I am not sure if I understood correctly. You want to display an image in a panel?
If so, you don’t need a datasource. There are at least 2 ways of doing it:
- You can use the text panel in the html mode (may or may not need to disable html sanitize in the config file) and use html tag
- You can also develop a panel plugin that basically returns an image
yes, the two options are great!
Thank you!
