How to include IMG in own plugin
I’m trying to use small images in my own plugin panel. After the build in the folder, I have images. But the grafana does not see them. How in the plug-in panel to import own images (.png or .gif) and then use them in css file?
It’s okay … I figured it out.
Hi, can you elaborate a bit on your method?
Thanks.
Regards,
Truong Chau Thy
