Grafana V8.2.3
ePict Panel V2.0.5
I want to display a string value using ePict Panel, it seems it is only possible to display a numeric value.
Is there a way to display a string value?
Grafana V8.2.3
ePict Panel V2.0.5
In case you don’t get any answers here, you can also try asking the author directly on the repository page.
Hi @marcusolsson
I created an issue on github, thanks for the tip.
Is there another way to display a string value on a picture?
The only one that comes to mind right now that does overlays like that is the ImageIt, but I think it only support time series data.
Might be long shot (and would require some configuration), but there’s also the HTML Graphics panel that lets you create dynamic HTML content.
