Display Strings in a Time Series
I need to display in a Time Series a free-string value. The problem is that Time Series in Grafana do not display string values, only numeric values. I want when you hover your mouse over the graph, display in the tooltip the string. It doesn’t work for me to value mapping because the string is a free-string field in my database. I’m using Grafana v9.5.2 in WEB version. Any ideas how to achieve this?
If you want to display something like this, then this will be helpful for you.
go to setting > annotations
