How to disable the new drilldown feature?
We are using the new Grafana Enterprise 11.6.0. Since then the new Drilldown menu is visible at the left menu. At the moment i am not able to hide this menu.
I tried to do it as i hid the Alerting menu. In the grafana.ini tried following configurations:
[drilldown]
enabled = false
[metricsdrilldown]
enabled = false
But none of that works. I also toggled the feature exploreMetrics = false, which only hides the submenu of Drilldown:
How can I disable the new Drilldown menu in Grafana 11.6.0? I couldn’t find something in the documentation about that.
Thank you in advance,
clasch
Hi! I think Drilldown in sidebar not hide, but i found how disable Drilldown functionallty
[plugins]
disable_plugins = grafana-lokiexplore-app
you can also try deleting the metrics plugin from your plugin folder
