grafana version 10.3.3
I would like to disable the download logs line button in the explore feature of Grafana and would like to know if it is supported. If so, how should I configure it.
This is to ensure that the content of the log is not leaked
Did you ever get an answer for this? It would be very helpful if you could share any solution you have found.
