How to disable a link on NaN values in table
A new column named ‘Logs’ is in table using add a ‘Add field from calculation’ transformation’. Logs column is created by adding 0 to existing column ‘State’.
But state has some blank values and hence NaN is getting added to ‘Logs’ column. when I add a Data link on Logs column a hyperlink is added to NaN also. I want to disable hyperlink for NaN values.
