I have a Grafana Table pulling data from a MySQL database. One of the fields in the database is a “url” field that I want to hyperlink from the Grafana Table. I have successfully been able to hyperlink the URL, however, the cell is showing the full URL. Can I change the display name of the URL in Grafana so I can shorten it? I’m fine with using the same exact display name for every single row.
Thanks
