How to create the admin role once it has been deleted
Hi all,
Apologies in advance, my knowledge is quite limited.
Installed Grafana on a RPI2, and at first login mechanically created a new user with a new password and deleted the default Admin.
Issue now is the user I created does not have admin authorisation, and I have lost the ability to login as Admin!
  • Tried the following: Purged and uninstalled Grafana: this does not seem to clean the user database so I have the same issue regardless of the version of Grafana installed (only one “basic” user, no admin user).
  • Tried to modify /etc/grafana/grafana.ini to set admin/admin authorisation as default, but it does not seem to create an admin user.
  • Tried to run grafana-cli admin reset-admin-password --homepath “/usr/share/grafana” newpass
But get the following error:
INFO[12-15|12:41:07] Initializing DB logger=sqlstore dbtype=sqlite3
INFO[12-15|12:41:07] Starting DB migration logger=migrator
EROR[12-15|12:41:07] Fail to initialize orm engine logger=sqlstore error=“Sqlstore::Migration failed err: unable to open database file\n”
  • thinking about running the HTTP API command to “boost” my basic user to admin level, but no idea on how to run the script from Linux shell…:
PUT /api/admin/users/2/permissions HTTP/1.1
Accept: application/json
Content-Type: application/json
{“isGrafanaAdmin”: true}
Any help would be greatly appreciated!
Please uninstall again and manually delete paths referenced here.
Marcus
This is definitely a Grafana bug, once you created a normal admin user, you could delete the super admin user. It’s easy to get it back, though.
  1. Create a user named admin with email admin@localhost
  2. then reset the password for it
bang! you get the super admin back
My super admin doesn’t come back… :frowning:
Hi Everyone,
We have a production environment in place where the super admin user was deleted, now even by using that recreate admin user tactic it still isn’t a supe admin,. How can we do this without having to go through a re-installation? This is very important.
Thank you,
Br
Diogo
I made the same mistake, and deleted all super admins.
Final solution was editing field is_admin in users tab inside file grafana.db from 0 to 1 for desired user.
Used db browser for sqlite.
that worked for me. thanks!
