User admin doesn't exist
Hi everyone
I lost super admin access, in another forum they recommended me to use the following command:
grafana-cli admin reset-admin-password admin
Throw the following error:
root@cnsmonitoreo:/home/administrador# grafana-cli admin reset-admin-password admin
INFO[01-11|10:33:19] Connecting to DB logger=sqlstore dbtype=sqlite3
INFO[01-11|10:33:19] Starting DB migrations logger=migrator
Error: ✗ could not read user from database. Error: user not found
Can anybody help me please, sorry for my bad English
I would suggest trying with API :
curl -X PUT -H "Content-Type: application/json" -d '{ "oldPassword": "admin", "newPassword": "newpass", "confirmNew": "newpass" }' http://admin:admin@community.grafana.com/api/user/password
Also check this thread :
Good Luck
Thank you wlargou, I am beginner in this, How I can use API in Grafana?
Did you try the command i shared (replace localhost accordingly).
Good Luck
I try this, but not work for me
CLI send me:
“message”:“invalid username or password”}
I would rather uninstall grafana
Yes if it’s new env :slight_smile:
So, I Can see the BD tables users of Grafana?
