Hi everyone,
I’m working with data in the following table format:
Time, UserName, Value
2024-10-22T00:00:00Z, User1, 10
2024-10-22T00:00:00Z, User2, 15
2024-10-22T00:00:00Z, User3, 5
2024-10-23T00:00:00Z, User1, 20
2024-10-23T00:00:00Z, User2, 25
I want to create a stacked bar chart in Grafana where:
- Each bar corresponds to a single
Time. - The
Valuefor eachUserNameis stacked on the same bar for that time.
I managed to calculate the total values for each Time using a group by, but in this case, I lose the information about individual users.
For example, with a group by:
2024-10-22T00:00:00Zresults in a total of 30 (10 + 15 + 5).2024-10-23T00:00:00Zresults in a total of 45 (20 + 25).
However, I want the stacked bars to preserve the breakdown by UserName so that each user’s value is visible as a separate segment on the same bar.
I’m using the Infinity datasource with the data in a CSV format.
Could someone guide me on how to:
- Transform the data if necessary?
- Configure the panel to display the stacked bars with segments for each
UserName?
Thank you in advance for your help!
