Hello!
I am a begginer on grafana, my english is not good but letβs go! I need create a interactive map with a table, this tables is a item on zabbix, this item return a json and i am transform this json in a table on grafana.
I need click on item and filter other items and apply a zoom on map in the item clicked.
I need help please.
Create a Dashboard Variable
Dashboard Settings β Variables β Add variable
Type: Custom, Name: selected_prefix
Custom options: your PREFIXO values e.g. AAA,BBB,CCC
Enable Include All option β Custom all value: .*
Click Update β Save
Add Data Link to your existing Table panel
Edit Table panel β right side β Data links β Add link
URL: /d/YOUR-DASHBOARD-UID/dashboard-name?var-selected_prefix=${__data.fields.PREFIXO}
Replace YOUR-DASHBOARD-UID with the UID from your browser URL bar
Add Filter Transformation to Table panel
Edit Table panel β Transform tab β Add transformation
Select Filter data by values
Field: PREFIXO β Match: Matches regex β Value: ${selected_prefix:raw}
Create Geomap panel
Add panel β select Geomap visualization
Use same datasource as your table
Map layers β Latitude field: LATITUDE, Longitude field: LONGITUDE
Add same transformation to this panel too
In Map view settings β enable Fit to data
Click any table row β table filters + map zooms to that location
Select All in variable dropdown β everything resets
Do your Zabbix JSON fields include LATITUDE and LONGITUDE?
Dear infofcc3
Thank you very much for you help.
Yes, my json include LATITUDE and LONGITUDE.
I using a datasource mixed with source panel on my table and transform and filter the data on latitude and longitude.
It was a success.
Thank you very much @infofcc3 !
