How to correctly provision custom data source
Hello there!
When using Terraform to create Grafana resources, there’s an issue where a GitHub datasource provisioned from installed plugins fails to properly connect to the plugin. Despite manually creating the datasource and ensuring database IDs match exactly, the Grafana API still doesn’t recognize the connection correctly. An issue has been filed with the Terraform provider (Datasource type is not bound to correct installed plugin · Issue #2220 · grafana/terraform-provider-grafana · GitHub), though it’s unclear whether the root cause lies with the Terraform provider or the Grafana API itself.
You need to provide reproducible example, with all used payload, responses, tf codes, …
I’ve responded in the issue - I’d say it would be easier to keep the conversation in one place and as @jangaraj mentioned, the more details the easier it will be to get an answer
Replied in issue, thank you!
