Hi everyone,
I recently transitioned from using Metabase and Tableau to Grafana, and I’m currently working with a MySQL data source. I’m using Grafana v8.0.1 and having some trouble configuring a heatmap panel — would really appreciate your help!
Data Context
The result of my query is in table format, with the following columns: store_name, created_at, and error_status.
My goal is to visualize error distribution across different stores in a heatmap — for example, how frequently specific error codes occur. The created_at column is just for time reference.
Issues I’m Facing
- When switching to the heatmap panel, I’m not sure how to properly map the fields (screenshot attached).
- There seems to be a difference between the current UI in Grafana v8.0.1 and the official tutorials I’ve seen, so I’m unclear on the correct setup steps.
- I’m also unsure whether I need to convert the data into a time series format or transform any columns beforehand.
Questions
- How can I properly convert this kind of table data into a heatmap? What should I set for the X/Y axes and value field?
- Are there recommended settings for parameters like bucket size or aggregation functions?
- Are there any recent tutorials or dashboard examples for Grafana v8.0.1 that I could follow? (I’ve already checked the official docs and video, but noticed some UI differences.)
Thanks so much in advance for your help!
→ simply select heatmap the table data show in heatmap visulaization
calculate form data → yes it will show the count on panel
or you can use transformation to manipulate data and show on panel
Transform data | Grafana documentation
using sql query also manipulate the data like this …
SELECT
store_name,
error_status,
COUNT(*) AS error_count
FROM
store_errors
GROUP BY
store_name,
error_status
ORDER BY
store_name, error_status;
Hi there,
Thank you for your reply and suggestions!
Sorry if my previous screenshot wasn’t clear—I’ve actually already tried converting the table data into a heatmap, but the result still doesn’t look as expected.
Just to clarify, one of the fields in my data is store_name, and since we have multiple stores, the ideal heatmap I’m trying to build would look something like this:
- Y-axis: Store names
- X-axis: Each occurrence of error codes (e.g., 2002, 2203, etc.)
- Color of each cell: Represents the frequency or intensity of that error (darker color = more frequent)
- Time info: Only shown in the tooltip when hovering over a cell, not used as a main axis
The goal is to visually identify how concentrated certain errors are per store during operations.
Given this setup, do you think a heatmap is the right chart type to use?
Or would you recommend a better alternative for this kind of data?
Really appreciate your help—thanks again!
I have tried as much as i can but still i can’t able to find out the solution but you can follow the document and similar example for better understanding .
Thanks
use Business Chart plugin
