10.2.3 -
I want to configure the Search Bar to be closed by default. I cannot use Kiosk mode since I still want to use the Time Range and ‘Refresh’ settings. -
I don’t want to use css to display:hide the bar, I have some users that still login.
Tried to use GF_FEATURE_TOGGLES_ENABLE_SEARCH=false as an env variable in docker-compose.yml
Have an search bar collapsed with the ‘Toggle Search Bar’ arrow pointing down. -
N/A -
Environmental Variable didn’t work. -
Asked a few GPTs with various answers, no good results.
Also (not a good solution for my use case): Is it possible set Top search bar collapsed by default? · grafana/grafana · Discussion #67650 · GitHub
