Forcing kiosk mode for users
I have finalized my dashboard in grafana and I have a user added with a ‘Viewer’ role.
My problem with the user is that they can still navigate through the top-bar and side-bar.
There is an option to turn on kiosk mode, but this can easily be toggled off by pressing ‘esc’, so putting ‘&kiosk’ in the address is also not an option.
Is there a way to force a user into kiosk mode?
Or from another perspective, is there a way to turn off function of the ‘esc’ key for kiosk mode?
I am using an open source version of grafana (10.3.1)
Thank you dude, the awnser was in there!
