I am using Grafana alertmanager, I setup MS Teams channel as a contact point and I am using custom notification template, is there any way to change or override url in “View URL” button in sent alert card, right now it takes me to the alert rules page, I would like to replace it with the link to the Dashboard. Thanks.
Welcome @rhabibov
Try adding the dashboard URL property to your custom notification template.
{{ .DashboardURL }}
Check the docs for the full example:
Hope it helps!
