I have a bar chart with x ,y and z axis , i want to modify the font size, color of 3 axis Value, how can i change that ?
You can change the font size with this:
For the color of each field/axis, you can override each one like this:
Overrides → Add field override → Select the field → Add override property → Standard options → Color scheme
