How to change a bar color in bar chart
Docker config on windows 11 + Grafana v11.2.0 (2a88694fd3)
I have a graph with values 0 or 1. I show 0 and 1 as green bars but if the Description for the tool contains the text (“MT1“) i want to color the green bar for example red.
I’m using a mixed data source and I join on Code
Influx:
import "regexp"
import "strings"
import "array"
from(bucket: "DEMALU_Francovera")
  |> range(start: 1970-01-01T00:00:00Z)
  |> filter(fn: (r) =>
      r.\_measurement =\~ /^S123547\\/BITS\\/E\\/E311/
  |> filter(fn: (r) => r.\_field == "value")
  |> sort(columns: \["\_measurement"\])
  |> last()
  |> map(fn: (r) => ({
      // Use regex to extract the part you want from \_measurement
         Code: regexp.replaceAllString(
          r: /.+\\/BITS\\/E\\/(.+)/,
          v: r.\_measurement,
          t: "$1"
      value: r.\_value
    |> map(fn: (r) => ({
      r with
      Code: strings.replaceAll(v: r.Code, t: "/", u: ".")
MySQL
select ni.Code,ni.Type,ni.Description,ti.Description as info from tb_nodeinfo ni left join  tb_toolinfo ti on ni.Name= ti.Name
Can you post a table view of your sample data?
But it sounds like “Value mapping” is what you are after.
Try this
CASE
WHEN description ILIKE ‘%MT1%’ THEN 1
ELSE 0
END AS is_MT1
then user add override propertry
value mapping in grafana
