I am displaying single values in a dashboard, where I have defined the unit as “kWh”. Now if the value is e.g. 1234.56 kWh, the dasbooard shows the value 1.2345 MWh. How can I avoid the change of the unit from kWh to MWh so that the original value is being shown?
Thanks and Regards,
Torsten
welcome to the
forum, @torsten67
This is a fairly common question. Here are some older threads with advice and suggestions:
in short, you can preserve the original form using misc / none but you will sacrifice the displayed unit feature
Since I want to display the unit as “kWh” I cannot use none/misc, but I found a workaround : I checked the Unicode table for an invisible character, and copied this in the beginning of a none/misc unit.
