Gauge switches from W to kW (although I selected Watts to be displayed)
I have several gauges that display my maximum power from my solar panels. I’d like them to always show Watts, however, if the number rises above 1000 W, it automaticly changes to kW. Is there anyway to prevent this?
Hi @henrizomer92,
By default Grafana performs calculation over numbers when using default units however you can override that if you use custom units which will just append string to raw number.
Instead using default unit Watt (W) in Unit box just type W and select Custom unit: W. Check next link:
Best regards,
ldrascic
Thanks a lot! I changed it; now waiting for some sun to double check, but I trust it will fix my issue :slight_smile:
