i want to find a way,that i can use grafana api to auto create panels and graphs of grafana.but i didn’t find the api,can you help me
There is no HTTP API for creating panels & graphs only for complete dashboards:
If you want to build dashboads programmatically you can take a look at
Wizzy is a good tool to import & export dashboards
Dear @hnzj13,
"grafana-client" - A client library for accessing the Grafana HTTP API, written in Python may also be of interest to you.
grafanalib-upload-dashboard.py is an example which outlines its usage together with the grafanalib library mentioned by @torkel.
With kind regards,
Andreas.
