How to Add TimeSeries Graph in Grafana New Table Column?
How can we create a time series bar graph inside the table?
I am looking for Query Load when the query was executing between the time range
Example:
Screenshot 2023-01-02 at 1.19.50 PM
Hi @asuwini,
Welcome to the :grafana: community support forums !!
Please review the submission template and include more details:
  • What is your datasource?
  • What visualization panel you are using e.g. time-series, bar chart, histogram etc?
  • What happened?
Hi @usman.ahmad ,
Thanks for the replying, Here are the details Kindly check it
    I am using Ubuntu Linux OS and Grafana Version
    Grafana CLI version 8.3
    Data source of this panel is Clickhouse
  • What visualization panel you are using e.g., time-series, bar chart, histogram etc.?
    I am using Table Panel.
    I am trying to add the time series graph inside the table panel.
    Not sure , I have created table and populate the data as per my requirement by using clickhouse data source. But don’t how to convert the static into time series graphs inside the table panel.
    No
    No
Hi @asuwini
Thanks for the answers.
So if the ClickHouse datasource is already configured then you must be getting some visual graphs (visualisation) based on the query you had defined for your need (I think this part is already completed on your side).
Now for the logs, you will need to use the Log panel visualisation and for that, you need to create a new panel within the same dashboard (as it is not possible for e.g. to view logs while using time-series visual panel within a single panel).
I found this official page which it explains as how to visualise the ClickHouse logs using Log panel visualisation.
Let us know if this helps.
