The query I have written for a join table query in a grafana dashboard panel to be pulled from druid
SELECT
"stream2:table.“coulmn1”,
“stream1:table”.“column1”
FROM “stream1:table”
INNER JOIN “stream2:table” ON “stream1:table”.“common_key” = "stream2:table.“common_key”
WHERE “stream1:table”.“condition” = ‘xxx’
The query grafana is running along with time range for the dashboard.
SELECT
AND __time >= TIME_PARSE(‘2021-12-31T18:30:00.000Z’) AND __time <= TIME_PARSE(‘2022-12-31T18:29:59.999Z’)
The Error I’m seeing
POST https://druid-dev.interactivedatastore.xxx/druid/v2/sql giving up after 1 attempt(s): failed to query Druid: {Error:Plan validation failed ErrorMessage:org.apache.calcite.runtime.CalciteContextException: From line 6, column 64 to line 6, column 69: Column ‘__time’ is ambiguous ErrorClass:org.apache.calcite.tools.ValidationException Host:}
This happens due to __time column being available in both tables.
How can I add changes to the panel so that query for time range looks like this.
AND “stream1:table”.__time >= TIME_PARSE(‘2021-12-31T18:30:00.000Z’) AND “stream1:table”.__time <= TIME_PARSE(‘2022-12-31T18:29:59.999Z’)
