How to add new users?
I am new to grafana.
I want to add new users.
I have an Admin role - i am the only user in the organization (I created it)
On User tab (under configuration) I have a button [Manage users on grafana.com] - but I cannt find anything there.
I dont have “Server Admin” option under “Configuration”.
(I dont know if I am “Super Admin” - how do I check it?)
I am using Hosted Grafana - for small teams ( 10 users included)
Thank you!
Aya
Hi, any update ? I would like to add a user too ! (it was easy on Grafana “non-cloud”)
Hi I found the solution ! you have to think “reverse” :
For example, if you, as an Admin wants to create the account for say - Joe,
  1. Ask the (future) user, Joe, to register to Grafana.com
  2. Ask Joe to you his account ID
  3. As an Admin, you go to https://grafana.com/orgs/ccoeviseo/members (where ccoeviseo is your Org pseudo)
  4. Click on the top-right hand side button [ +Add Member ]
  5. Enter the User Name (not the email of Joe !)
  6. Then choose one option : “Viewer / Editor / Admin” and the Org/public
  7. validate “Add Member”
    Yes !!
    Note : I was trying to add his Github account and other stuff… just forget that ! it’s on Joe’s Side to choose this login way.
Hope this help ! As I have created two Grafana Cloud with different ways to check what I got it wrong in the first place !!
Why couldn’t we just use B2C SSO of Github or Google and use those account as guest-account of the Grafana’s one ! it would have been less painful ??!
