Create Admin User and Add it to All Orgs
    Grafana V7.0.5
    Create Admin User and Add it to All Orgs. It can be through API or any other method.
    It could be via API
  • What happened?
    Don´t have a clear method on how to achieve that
    Create user that is in every Org
    No errors
I was thinkin it might need to be done via API. Any help?
Yup, doing it via the API is the way to go. You would need to write a script that (a) gets a list of all orgs (relevant endpoint: Organization HTTP API | Grafana Labs) and (b) loops over them and adds the user to each one (relevant endpoint: Organization HTTP API | Grafana Labs). Hope that helps!
