How to add nestedFolders using http api
    Grafana v10.0.1 (5a30620b85)
    Create a nested subfolder using the http API.
    I can’t find any documentation on how to do it and the feature doesn’t seem to exist in grafana-api-golang-client/folder.go at master · grafana/grafana-api-golang-client · GitHub
    curl or preferably using the golang SDK
  • What happened?
    N/A
    Documentation how to use the nestedFolder API
    There is no documented way on how to create a nested folder.
    N/A
    Folder HTTP API | Grafana documentation
It seems like the http API schema has been updated.
Watching my http traffic when using the API it seems like you now can do:
{title: "lalal2", parentUid: "ad21a11d-5c5b-440e-98d9-969342cd8e9e"}
Now the question is it worth to send in a PR to the go sdk , or will it be fixed by Use `swagger` to generate Go client for Folder service by nikimanoledaki · Pull Request #155 · grafana/grafana-api-golang-client · GitHub?
