Create folder by rest api in an specific organization
  • Grafana version: 9.3.1
  • I´m, trying to achieve: the creation of folders by rest API (postman) in a specific organization. Example orgId=5.
  • I´m testing by Postman
  • I´m following the documentation to do so.
But there is no explanation about how to create in a specific organization (orgId=5)
  • So I tried to send the “orgId”: 5 on the body payload, but still create on the Main organization and that is what I don´t want.
  • Also I tried adding to the URL ?orgId=5/ like this:
grafanaURL.com/api/folders?orgId=5
grafanaURL.com?orgId=5/api/folders
Not working too
    I need and expect to create a folder in Organization 5
  "uid": "nErXDvCkzz",
  "title": "Department ABC"
  "title": "Department ABC",
  "orgId": 5
Not found ← This is the error that gives me.
