Create folder from an Org HTTP API
    8.5.20, ubuntu 5.4.0
    Create a folder inside a specific organization using HTTP API
    Generating a HTTP POST request to the url ‘/api/folders’ with the required json data.
  • What happened?
    The folder is created in the organization with id 1 (Main org).
    To be able to indicate the orgId at the moment of creating a folder.
    The json data:
    data = {‘title’: nombre}
    No
    Folder HTTP API | Grafana documentation
