I’m trying to search multiple values (comma separated) in a text box variable. But when I’m trying to get the value using the variable, it gives me as a full string. How can I get the comma separated values in an array from?
how do you want to use them? And with what data source?
You can’t change the value of the text box to an array. It can be done only with the drop-down variables Variable syntax | Grafana documentation.
However, if you want to query something using the text box, try this:
