How to add image + CSS in Stat?
Guys, I’m creating a dashboard using the Stat plugin to return the name of my item and its value.
In this case:
Name: Connections between 0 and 10 minutes
Value: 4981
So far so good, but looking on the internet, I saw some dashboards that remind me a lot of using STAT but with a very interesting customization, where it is possible to change the background by adding elements as if it were CSS.
Can someone guide me on how to use STAT to create something similar to this:
or inform me if it is with the stat plugin itself that this type of customization is done.
Hi, it does not look like the stat-panel.
I suspect it’s not the STAT either, as I’ve already searched through its options and didn’t find anything that does something similar.
The plugin I came closest to that does this is Dynamic Text, but I’m not sure…
Easy peasy to reproduce with the flowcharting panel.
But thank goodness it will soon no longer be supported. :wink:
You can try the new “flow” plugin.
doable via dynamic text
