I currently installed the Clock plugin from Grafana…
How can I add this to the dashboard? I only have the following panels types to chose from:
Regards
SchiSchi
Regards
SchiSchi
Hello Schischi,
Choose visualization on that screen and then choose the clock in visualization panel
I hope it helps
Updated my Grafana to the newest version… works now as described.
Thanks!
