How to add a row as an exception to threshold values?
Actually I think it can be done uf your override value mapping range are 0-79 and then another one 81-10000
Then another one just for 80
Granted the plugin recommended by @mikhailvolkov you have more control and range of things you can do
Try it out
Actually 80 is not static, it can change, the logic should be based on value column Z has like I mentioned
@adityavermamanit Have you tried to implement it using Dynamic Text? Did it work?
Haven’t tried it yet, I am bit reluctantly to use all that HTML into my dashboards.
