Grafana: 9.5.2 or preferably 11.2.0
OpenShift: 4.14/4.15
OpenShift Loki-operator 5.9.5 -
Authenticate against the in-cluster Lokistack and retrieve logs into Grafana while keeping access to Logs separated by namespace admins for multitenancy. -
Following the docs or this forum post’s solution. -
What happened?
Got authentication working and was able to explore “Audit” and “Infrastructure” logs, but nothing from “Application” or the Prometheus metrics. -
Also to have access to the “Application” logs and preferably the prometheus metrics. -
Grafana v11.2.0 Pod found 7 lines like this:
logger=sqlstore.transactions t=2024-09-11T07:18:48.236990538Z level=info msg=“Database locked, sleeping then retrying” error=“database is locked” retry=0 code=“database is locked”
Also found this set of logs multiple times:
logger=authn.service t=2024-09-11T07:19:02.849602701Z level=warn msg=“Failed to authenticate request” client=auth.client.session error=“user token not found”
logger=context userId=0 orgId=0 uname= t=2024-09-11T07:19:02.849654018Z level=warn msg=Unauthorized error=“user token not found” remote_addr=redacted traceID=
logger=context userId=0 orgId=0 uname= t=2024-09-11T07:19:02.849687394Z level=info msg=“Request Completed” method=GET path=/api/live/ws status=401 remote_addr= time_ms=0 duration=649.773µs size=40 referer= handler=/api/live/ws status_source=server
In the Grafana UI:
Forbidden (user=, verb=get, resource=prometheuses, subresource=api). Probably a misconfiguration somewhere down the line.
