Hello
i’m trying to forecast some information tat i’m sending from Azure Log analytics to Grafana Cloud, but i cannot find a way to measure how many active series, Logs, etc are consuming those dashboards and panels.
Does anyone know a way to achieve that,
Your help will be much appreciated
Thank you
Stiven
Your Grafana cloud Grafana instance has folder GrafanaCloud, where you can find usage dashboards, e. g. Billing/Usage.
