How i can click on one panel of the dashboard and use that value to refresh other panels with the value captured in previous panel
The same case requires
Currently I don’t think that is supported, the only supported link between panels is the timeframe (if you zoom on one panel the others are also zoomed to that timeframe).
Hope it helps.
Good Luck
