Hello Grafana Community,
I couldn’t find any documentation explaining the mechanism behind how Grafana refreshes data on dashboard reload, so I’d like to ask a question here.
Let’s say I am using the Infinite data source and running a query with from: now-1h, to: now. If I set the refresh interval to 1 minute, does Grafana:
- Shift the time range forward by 1 minute and fetch only the new 1-minute data?
- Or does it run the query again with from: now-1h, to: now using the current timestamp at the time of refresh?
I’d appreciate any insights on how Grafana handles this.
Have a great day!
I’m Using v10.2.0 Enterprise Edition on Linux -
Find mechanism of refreshing dashboard on Grafana -
What happened?
